Hi all,
First post in the Plumbing Forum so excuse any lack of technical details.
My sister has a problem with her central heating - it only seems to work when it feels like. (A bit like the rest of us, I suppose!
She has a back boiler behind the fire, on which the pilot light is lit, but when the heating is switched on it currently fails to fire up but it works fine with the hot water. There is a hot water cylinder in the airing cupboard. The thermostat in the hall works fine when the heating is actually on, as does the control switch in the airing cupboard.
A couple of months back the three port valve was stuck and the heating was constantly on so I pushed the switch manually and everything began working properly again, until last weekend. Assuming it was a similar problem, yesterday, I went to push the switch manually again but it wouldn't move. The other switch on the valve was in the correct C position for the central heating only.
I could hear the pump below trying to work but it wasn't kicking in properly so there was no heating. However, last night my sister said there was a lot of gurgling and the heating came on of it's own accord but only the downstairs radiators were working. This morning the downstairs rads were cold but the upstairs ones were just warm!
I tried bleeding the rads this morning - the only one with air in is in the bedroom and there seemed to be lots of it. However, the air stopped coming out after a few seconds but no water came out so I think there is still a fair bit of air in it which is trapped.
There you have the problem, along with all the information I can think of, so can anyone please advise what the solution is:
3 Port valve?
Pump?
Boiler?
Airlock?
Other?
GHOST!?
Cheers,
mrH.
3 Port valve?
Pump?
Boiler?
Airlock?
Other?
GHOST!?
Cheers,
mrH.
