Hey. Before i ask my question and describe my problem, the following info is probably useful:
It's a repo'd house - was empty for a year and no contact with the previous occupants.
Upstairs of house is bare floorboards and easily accessible.
We have 6 radiators - 3 upstairs and 3 downstairs. They are on microbore pipe (teed off from 22mm pipe feed and teed back to 22mm pipe return) and two get hot upstairs and only one hot downstairs. The water pump is new and the hot water works fine.
Upstairs we have nothing plugged into the plug sockets and the pump/thermostat/diverter valve hard wired in.
Downstairs we have the boiler, the oven and hob wired in on plugs, the washing machine wired in on a plug and the boiler and function controls for the heating/water are also hard wired. We have a computer plugged in and the fridge-freezer plugged in.
Ok - when we first moved in, the house was completely empty and all services shut off. We got everything working and up and running fine. Water and electric work fine, and a device my old man gave me which plugs into the sockets and tells you whether they are working is showing that all sockets are working perfectly.
On the third day we were here we were lying on the bed (after i'd put it together) about 6pm, and this weird buzzing noise started happening. It was difficult to locate, but it appeared to be coming from the floor under our bedroom. I went downstairs and i could still hear it there. I then turned everything electrical off and it was still going, and then it suddenly stopped after about 5 minutes.
Not heard anything since, and the above happened on Sunday.
This morning, i was woken up at about 9am by the same noise, albeit a little bit louder. I got the floorboards up in our room and i can see a big bunch of wires coming through the floor from the consumer unit which is under the room in the hallway by the front door. Water pipes are running alongside the main electrical wires and although the sound was difficult to pinpoint it appeared to be coming from that general area.
There is still a tiny bit of air in my heating system i would presume, as the system is only warming 3 out of 6 radiators, i don't know whether this makes a difference.
Again the sound just randomly stopped after about 5 minutes.
This isn't a huge concern it's just doing my head in not knowing what it is. Can cables hold charge even when the consumer unit is completely switched off, hence the sound not stopping when i powered off? Or is it more likely to be pipes? I thought this was the best place to ask as the sound sounds like a loud version of a humming dimmer switch or something.
Thanks in advance for any help.
ALSO - just me in the house last night and this morning. No appliances were on before i heard this sound today.
