I'm looking at creating an en-suite and whilst looking at walk-in shower trays (1700x900mm) I started to feel they were quite expensive and the step needed to get in to them started to put me off. The obvious answer is to create a wet room but the thought of them makes me nervous. I understand there are low entry trays but as they still require the waste to be below floor level I might as well go for a wet room. So around this subject I have a couple of quick questions that I'm interested in having people's opinions on:
1) Do you need to include under floor heating beneath the floor tiles or is it ok to leave this out? I will have quite a powerful heated towel rail so the room should be warm enough but is it better to have UFH to reduce excess surface water and to help it dray?.
2) If you tank the floor wouldn't it make sense to tank the walls in the enclosure to avoid tiles lifting?
3) How do you get the fall on the floor? Is it done with the tile adhesive?
4) I've done a fair bit of DIY but am I best to get a professional to install the tank and do the rest myself? I don't trust many people's work and I can't think of anything worse (sure I can) than paying someone to do it then in 6 months time find I have a real problem and have to rip it out and re do it.
Thanks for any advice.
