Wet room
5 Nov 2010
Bristol
Hello all.
I would like to have a wet room in my loft, I have been quoted for a bathroom with shower no bath. I will have a sink and a toilet and some storage but do I need a shower enclosure and tray?
What material must I put on the floor ie: water proof tiles etc and how do I stop the water going underneath the door into the hallway?
Waiting in anticipation
P
Read more: //www.diynot.com/forums/building-regs-planning/wet-room.329642/#2446244#ixzz1zkC6uJKY
A bathroom fitter that does wet rooms would awnser these questions when he quotes.
You don't need a shower tray if you don't want one
Their are lots of options on tanking
You can buy a screen, or set toughened glass into a channel in the wall.
The tiles will be swept into a fall back to the drain set in the floor
You don't need special tiles, although something Too smooth would be a slip hazard
Warm up under tile heating is a good idea, as it takes the chill out of the tiles and helps dry out the floor.
Don't put it under the toilet!
Thanks for that. I have a quote for a complete loft conversion, I asked to have a wet room but he hasn't quoted for tanking etc. instead he has included shower trays and shower enclosure. I just wanted to be sure of what his intention is.
Thanks once again
The difference in doing a wet room or shower etc is that a wet room is more costly on labour.
It's a much more specialist job.
I would get an independent wet room installer to do this side of the installation.
Bathrooms etc always come out better done by one multi tradesmen ( if he's good) than various tiler, plumber, carpenter. Because it's all about allowances and each stage prepping for the next which then comes together as a whole at the end.
