Hey all just looking for some advice. I’ve noticed that every time I put my heating on the corner in my living room becomes wet to touch. Any idea what could be causing this ?
If the boiler is above where it’s leaking then check the condensate pipe, if there is one, is connected and not damaged. Could do with more information - boiler type, do you have an unvented cylinder, do you lose pressure if sealed system?
Condensation on walls when a boiler fires up indicates a possible leak of products of combustion which can kill turn it off and get it checked asap .
Do not fanny about doing anything else suggested in here first
If it is only in one location and only happens when one radiator comes on then what has the boiler got to do with it?
Boiler may not even be in the same room as where the water is leaking.
Most likely cause is a leak, either in piping that feeds radiator or if at radiator then on the radiator itself.
