Hello
I am a student and I am doing a project on wet rooms in the UK.
Is there anyone out there that can help me answer the following questions for my project:
1. Sealing of the floor – Which systems are common in UK? have only designed for composite water prooving systems.
2. The height of the floor – what is the minimum floor height, example of 90mm + the slope of the floor.
3. Is a 50mm PE outlet bend connectable to the PVC systems in UK?
4. Is cross floor oder same floor drainage common in UK?
5. Situation on the building site -> there are steps which needs communication between the plumber and the tiles layer … are they communicating with each other?
If you could help me this would be great.
Thank you
Thank you
