I am currently refitting the bathroom. I am putting a bath in which will have a shower area at one end. At the shower nd of the bath is a stud wall onto which the shower will be fixed, the other wall the bath is against is the block/ brick gable wall. (currently cleaned back to the brick)
These walls will both be tiled to finish.
I was going to use aquapanel on the studwork then get the solid wall plastered, but then i should probably tank it anyway. So should i just use plasterboard/ ply, plaster the solid wall and tank the whole lot? Or to svae me money should i dot and dab the soild wall and tank this? would that hold up tiles ok and is it possible to get a level flat surface with dot and dabbing?
What would you do?
What would you do?
