So i had a good read about lighting circuits and how to fit a light fitting safely etc.
But ive done a couple lately and the fittings are incredibly awkward and the terminal is ridiculously close to the outer rim of the light fitting, so in order to get the wires in they bend practically 90 degrees. So ive been wondering, if the live/neutral/earth slipped out at any point (ive made sure they were tight when i put it up but you never know) what would actually happen in each case?
If the live and earth slipped out then the light wouldent work, so if you turned off the circuit at the mains before touching you would be ok surely? What would happen if the neutral came loose?
