What drill bit to put pipe through wall
7 Jun 2008
Kent
I need to put in a garden tap, for which I need to run a standard piece of 21mm copper piping through one exterior wall (about 15cm thick - do I need to get a core drill or is there some kind of heavy duty long masonry drill bit I could use??
Good idea to run a smaller sds through first to prevent too much break out on brick side (unless you are drilling from out to in of course!)
