What insulation?
13 Jan 2016
What insulation should be used in the floor voids? The spec states '150mm mineral wool' and I can't get hold of the building inspection.
Can I use Loft roll? E.g. Rockwool?
Same question again, what should be used in the studwork? Spec states '50mm insulation quilt'.
I presume not cavity insulation & loft insulation doesn't come that thin. So what exactly am I looking for?
Thanks in advance
Is this a ground floor? (If it's not a ground floor, you should consider a product with good acoustic as well as thermal properties.)
Your choice is roll or slabs. If you're lucky you'll find something that is the right width to fit between your joists; if not you'll have to cut it to fit.
Rockwool Flexi slabs are supposed to be available in 140 x 400 x 1200mm which might be what you need.
Yes it's the same material as loft insulation.
Again you can choose between slabs and rolls. If the stud spacing is 600mm consider http://www.insulationexpress.co.uk/Timber-Frame-Insulation/Rockwool-Flexi-Insulation-Slab.htm (1200x600x50) or http://www.insulationexpress.co.uk/Multi-Purpose-Slabs/Earthwool-Flexible-Slab.htm (also 1200x600x50).
Again you may want something with good acoustic properties (e.g. to keep noise out of bedrooms); see http://www.insulationexpress.co.uk/Insulation/Acoustic-Insulation.htm for various products.
Lots of products are available. They are all pretty good. The main differences are cost, availability and in some cases how friendly they are to fit i.e. are they "soft" or "scratchy" to the touch.
