I can see no reason why a 'smart' meter would be required when one is doing some export IF both import and export were single-rate or, at most, 'fixed-time' dual-rate tariffs. My 'dumb' meter has the ability to record import and export separately for the two 'fixed' ('peak' and 'off-peak') periods - but the meter then obviously has to be read manually (by myself or a meter reader).However, the whole question is a "suitable meter" where smart meters will not work.
However, that's a big IF, since I'm not at all sure that any supplier offers a single-rate or dual-rate tariff including export (and nor whether anyone would want such a tariff).
The moment one wants a tariff which (for import and/or export) is 'dynamic' and/or which has more than two 'rate periods', there really is no option than to have what we call a 'smart' meter. I can't see that anything other than what we call a smart meter would be "suitable"! for such a tariff", no matter what Ofgem might say, can you?
The obvious solution would presumably be for them to implement some workaround to facilitate communication with a standard 'smart' meter -in which case "...cannot fit a 'smart' meter" would not arise?
