- Joined
- 27 Jan 2008
- Messages
- 29,799
- Reaction score
- 3,694
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Part L allows a 2% decrease in efficiency and my interest is the use of wood burners. If a home has for example gas or electric heating would this rule prevent the fitting of solid fuel which is only typically 60% efficient?
Second is ventilation where an intermittent fan is installed in the kitchen which has to be greater than 30l/s would this need changing to a heat recovery device because of the 20l/s limit with an open-flued appliance? In fact would a heat recovery device be allowed or is the 20l/s limit also applying to these.
Can positive ventilation replace the negative ventilation and so comply?
I have been reading through the Part L, F, and J on line guides and it would seem it would be a problem to change to solid fuel and comply. Views please.
