Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
To prevent sheets buckling due to a change in moisture content, manufacturers recommend they should be conditioned before use. There are two ways of doing this.
For standard and LM (low density) type medium and tempered boards, scrub the backs with water, using I litre to every 2440 x 1220mm sheet. Then stack the sheets flat, back to back, for 24-48 hours (48-72 hours for tempered boards).
For HM (high-density) type, medium boards and all boards to be used in centrally heated surroundings, stack the sheets on edge in the room where they are to be used, separating them with wood off cuts to allow the air to circulate. Leave HM medium boards for 48 hours and other boards for 72 hours before using them.
