What kind of Vokera is this?
26 Jun 2004
London
I am slightly guessing its a Vokera as it has a bottom plate and valves like an Excell but an insulated plate HE and a gas valve mounted centrally but turned sideways with mod coil on right. Fan mounted at an angle on left of smoke hood.
It was dark when I saw it so did not notice much more!
Any suggestions?
Tony
Does it have a large alloy main HE? If so it is 'Eclipse', early condensing. If it has copper main HE it may be 'Elidra', ltd. edition std. efficiency air-gas modulation unit.
Its not condensing and generally similar to an Excell as if its a late modified version but I could not see how it sensed hot water flow or diverted or if its a four pipe HE.
Its the first time I have seen one like that.
Tony
Went to see it again in the light!
Its actually a Linea !!!
But in the dark and without the pcb carrier or the diverter motor actuator it looked rather different!
Tony
