What mix of concrete should I use?
16 Jan 2018
I need to make a cavity floor repair due to the relocation of some pipework and am just wondering what would be the best mix to use? I have never concreted before so nothing is obvious to me! :) I was wondering if I would need to do anything special as I need it to bond with existing concrete,
Please see the picture here https://1drv.ms/f/s!AjnJhtmhYMJlhpZmWfHQBA4kbB8DGA
Any advice would be greatly appreciated!
I guess its screed?
1part cement to 3parts sharp sand
Im not sure what prep is needed, it looks like a floating screed so it needs connecting well to the original or it will tend to break up.
Is that insulation underneath?
Thanks for replying!, Yes it is insulation, I have some new insulation to lay down first to line up to the existing, should I then put a bed of sharpsand down on top of the insulation first and then screed? I have heard of some formula you can paint on existing concrete to help the bond just need to find it! :)
Usually PVA is used for something like that.
I did wonder whether some holes should be drilled and some rebar resin'd in as you are effectively forming a day joint.
Are you proposing to bury those push-fit pipe fittings in or under concrete ???
no, they are just temporary until I plumb the new towel rail
Thank you Notch, I will look into rebar :)
Im not sure if thsts the best dolution, but screed on top of insulation is not too bad if it is 1 complete slab, once cut, you have a few weaker bits of screed sitting on the insulation and day joints could work apart.
Im sure a builder on this forum will be along to advise a practical solution......
I was wondering about strength.. should I have posted this in the building section?
