What paint to stop stain seepage ...?
12 Feb 2010
Southampton
We've taken off our wall-to-wall stairs carpet (20 year old 'estate' house), and we're replacing it with a carpet runner and stair rods, so the sides of the treads and risers will need glossing where they're now exposed. They've been painted before, but the issue is the old carpet underlay, green, had decayed and left yellow 'oily' looking marks on the woodwork. After a bit of sanding and prepping, I've painted the sides of the treads with Dulux Once satin- but I've noticed that the yellowish stain has come through! I don't have the time (or inclination!) to sand 14 treads and risers back to bare (cheap, not attractive) wood in order to start from scratch, so-
Can anyone recommend me a paint or sealant I can now use to stop this yellowing coming through a second layer of Once?
Thanks!
B
blightymam
Probably not the right paint for the job using a one coat! But you could try polycell stain stop or zinsser cover stain then try again. Both should work ok..
12 Feb 2010
Southampton
Thanks- do you think I need to sand off the 'Once' in order to apply the zinsser, or oil-based undercoat; or can I apply it on top of the Once?
B
blightymam
You could give it a light sand, just to make sure you've a key but no, no need to sand off completely.
