We have a en-suite with a tile shower cubicle on a shower tray. Last week I noticed a damp patch on the ceiling downstairs directly under the shower so I had a look at the grout on the lower tiles and it seems to be leaking. I pulled the tiles off and the plasterboard behind the tiles was soaking and mouldy. I ended up ripping the whole shower and walls out as they were pretty wet.
I wil probably get someone in to fit a new shower/wet room but want to do as much of the easy stuff as possible to keep costs down.
My first question is in relation to the plasterboard to use. I plan on either having the shower area either completely encased in tiles or shower wall panels . My sons bedroom is adjacent to the shower room and you can hear the shower in there when it is running so I also want to have the noise reduced. I was looking around and there are three possible choices:
- Soundbloc gyproc
- Moisture resistant gyproc
- Hardiebacker board.
The sound bloc stuff does say it has some moisture resistant properties but its main purpose is to reduce noise (not sure how effective it will be though as I don't plan on installing the other fancy stuff to reduce noise such as metal studs between plaster and batten) The moisture resistant stuff seems to cover my use and the hardie board says it is moisture resistant and specifically for tiled areas to support the weight. What type of board should I use if the entire area will be covered in either tiles or shower wall?
The second question is to do with the wall insulation. There was rock wool there already but it got wet and was really damp smelling so I removed it. I was going to replace it with earth wool as my local B&Q has it on offer but someone at work told me I should use some of the solid insulation slabs such as kingspan as it will help with noise but I always thought that stuff was for external wall insulation. Any advice on this?
Regards,
John.
- Soundbloc gyproc
Regards,
John.
