what size combi for 2 bed terrace???
4 Jan 2014
Durham
hello,,,I'm about to get a new boiler fitted in the next few weeks,,,i have a small 2 bed terrace house with six average size single rads,,,a towel rail and a shower,,,how big of a boiler do I need???,,,the rads are piped in 8mm copper,,,is it worth getting a mag filter???,,,would the warranty still stand with it being piped onto an old system???,,,baxi duo tec or baxi main???
Why don't you ask the installer who can discuss your needs and view the property.
Are you having a combi or cylinder system?
Usually 24 kW or 36 kW for a combi as they are rated on hot water output.
For a cylinder, the heat loss of the property, maybe 8 or 10 kW in your case plus 2 kW for water heating. So probably a 12 kW boiler.
You need to calculate the heat loss of your property or ask the installer for help.
Tony
For your heating requirement, probably about 5kW. For your hot water requirement, it depends partly on what your incoming flow rate is
Yes, always, as well as a thorough flush of your system with cleaning chemicals
Provided the system has been cleaned and inhibited properly it would, yes
Am I allowed to say neither?
Do check before you buy any boiler that the maker will warranty it on an 8 mm system.
A poster here said that Worcester do not accept microbore!
gas lad says 28kw will give better shower power,,,rather than a 24kw,,,theres not that much difference in price to be honest,,,about 130 to 150 from what ive been looking at......
