Yes, massive crop this year, even with lack of rain.
I did not have an angle grinder when I laid the first lot of paving slabs, and I ended up with a gap which needed filling, so a long thin flower bed was formed to take up the space.
The hedge to right and apple tree above mean this strip does not get much natural water, only prolonged rain reaches this strip, and the flowers etc, have suffered this year. Had a problem from the balcony even seeing the strip due to apple tree. From under the apple tree.
As can be seen not doing well, and this was planted last year. This year shed other side replaced with steps.
The flowers to hide the sleeper wall have come on well, I expect the ash used under the steps will settle, so not cemented yet, that's next year once settled.
We did not water the grass, with so much hype about water shortage, we decided to leave it. At least have not needed to mow it.
So for 5 to 6 days we have had some rain. But no really heavy rain. When I realised plants under the apple tree were dieing off, I did water them a little, but I would have thought no need to water plants put out last year?
The rhubarb two plants, one really doing well, the other just a few small leaves
the second plant at top, nearly died off, a bit of water seems to have kept it going, just 4 small leaves, it did early in the year have leaves same size as the lower plant. I suppose the two plants are too close to each other?
Problem is, I have never really bothered about the garden. So really not a clue what I should do.
