What watt electric shower
10 Apr 2006
Hertfordshire
I want to replace an electric shower.The one that was here when we moved in does not work. I dont know what wattage it is. How do i know what wattage to buy? I dont want to buy the wrong thing.
see what size cable feeds your shower - if 6mm then no more than 7-7.5KW at a push or if 10mm you can go higher if you want
and check the circuit breaker / fuse / RCBO / MCB at the fuse box / consumer unit
the old shower might have a label on the bottom saying its power in kw.
I found out that the old one is a 9.5 kw and the cable looks like a 10mm we also have a seperate fuse box thing for the shower. would like to get the mira 10.8kw shower, hope that will be ok.
lucio said:
on the shower switch on the cu reads 240/400v.
That's just the voltage rating of the switch.
Do the math and compare with the breaker supplying the cicuit.
10500 divided by 230 equals ???Amps
