Whats a CH drain plug on the return pipe ?????
small spurr off of pipe.. little square bit5mm across to open spur... check at lowest point on your ch system and also next to the boiler
Right- it should look like a little brass valve type fitting,fitted onto one of the heating pipes at low level-favourite places are near a front or back door-hallway or kitchen,it will have a little spout on it just the right size to put a half inch hose onto to drain the system,there is a little square end on the end of the valve that you can turn with a small spanner-this will open the valve. Of course this is all supposin you have one fitted at all because i've seen plenty of systems with no drain off anywhere-then you have to improvise and use one of the radiator valves as a drain off. :)
check my skillz lol
OK got it it's located on the outside of my house poking out of the air brick so if i close the CH valve and open this will it only drain the boiler or the whole system ? :shock:
Well-it will drain the whole system unless-you turn all your rad valves off-then it will drain everything except your radiators. :wink:
