What's a good flow rate for a bathroom basin?
Discussion in 'Plumbing and Central Heating' started by butako123, 30 Oct 2021.
  1. butako123
    butako123
    25 Oct 2020
    12
    Thanks Received:
    united kingdom
    Country:
    Were having our upstairs bathroom replaced. Our system is gravity fed pressure from tank in the loft. It seems to be a trend that modern monobloc single lever taps seem to have quite low flow rates, to save water. My wife likes a Hansgrohe tap which is rated at 4 l/min at 0.2 bar. Which sounds quite low to me! (Our old taps I measured them at 8 l/min).
    Is 4 l/min just a dribble or good for cleaning teeth/washing hands? Are there recommended building codes for minimum flow rates? Would you be happy with 4 l/min in your bathroom sink?
    Here is the tap, looks beautiful: https://www.hansgrohe.co.uk/article...-min--0-2-bar-without-waste-71101010#techdata
  2. Sponsored Links
  3. Munroast
    Munroast
    17 Aug 2010
    2,013
    Thanks Received:
    292
    Country:
    why do you not reduce the flow from your existing tap to 4l per min, (you could probably do this from the isolating valve on the pipe leading to the tap) then asses over the next few weeks if it is sufficient.
    just measured 4 litres per min, and it is tediously slow. Of course you will never know how well it flows until it is fitted, your water pressure may be above 0.2bar, I have no idea if that is high or low on a gravity feed.
    • Thanks Thanks x 1
  4. butako123
    butako123
    25 Oct 2020
    12
    Thanks Received:
    united kingdom
    Country:
    thanks Munroast. Don't have much time as the bathroom work has already started.
    What is the "normal" for bathroom taps? Surely there must be some industry guidelines or regs about what is good/bad flow rate?
  5. denso13
    denso13
    22 Jan 2007
    6,766
    Thanks Received:
    1,189
    Country:
    Not really, just set your kitchen sink tap to 4l/min and see what you think.
    • Thanks Thanks x 1
  6. Dereekoo
    Dereekoo
    2 Jan 2012
    445
    Thanks Received:
    68
    Nottinghamshire
    Country:
  7. denso13
    denso13
    22 Jan 2007
    6,766
    Thanks Received:
    1,189
    Country:
    Nothing to do with minimum mains pressure/flow, we are discussing a cistern fed system.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
