Got quite a diverse route between the loft shower mixer and the negative pressure pump on the 1st floor.
The best option would be plastic with a few gentle bends, someone mentioned Hepworth as the best pliable pipe, do you agree ?
If I can get away with zero joins between the mixer and pump it will allow me total confidence to tile over, keep the water running without any joint area resistance (90 deg bends and straight connectors) and generally be easier than 22mm copper.
Any recommendations appreciated, since the last 22mm plastic I worked with was so rigid it required popeye forearms to straighten it off !
Also does storing the pipe, say in the airing cupboard for a day 'soften' it off to work on, or is that a simple myth.
Ta
Chris
Ta
Chris
