what's this
24 Nov 2004
this is not necessarily in any way electrical. and is therefore completely off topic. I would very much appreciate the moderators indulging this post though, I am after exposing it to the particular flavour of brains on this forum that may be able to pass informed comment.
it was found with a metal detector in the garden of a 1930s house in the scottish borders.
I think the dinks in it have probably been caused by a motor lawnmower.
the blue substance in the 'female' end of it appear to be nylon or plastic of some kind.
body is mostly nonferrous.
there may be traces of a ferrous metal in the nose of the male end of it. (rusty deposit)
Huh?
I reckon that is only part of the object.
It contains copper, has an easy-to-grip exterior and appears to be threaded internally.
Could it be part of a writing implement?
Could the blue stuff be wax?
It may not have originally been part of the item and could have been added later.
It could be, but I'd be more inclined to suggest a "Pin Vice" (I think that's what they're called), essentially the "Miniature drill bit holder" that has already been suggested. There is one in my late father's 60-year-old toolbox of 'precision tools'.
Kind Regards, John
Of course.
What's broken off the sharp end is the point of the dart, and in the other is the remains of the shaft.
I couldn't think of anything other than a pin vice, but I was concerned that I couldn't see any way to open/tighten it.
A cheap and nasty dart at that. One of those with plastic flights. This one had gaudy blue plastic flights.
My Mother had a set just like that, From the 50's Called them Brass Bullets they were about twice the weight of modern darts, and would destroy a modern cheap and nasty dartboard ina few games!
look at the unicorn set on here:
I thought it was only me that remembered when darts were a proper weight. :)
And when I was at school, we used to saw the point off and turn a short parallel section on the nose - the right size to be a tight for for those caps that came in red rings and made a much bigger and more reliable bangs than the paper strip type. Cut the rings up to get individual caps, and you've got a semi-precision, short distance, bang delivery system - so you could give someone a good "surprise" without having to creep up behind them :D
Easier to make some nitrogen tri-iodide, I would have thought.
Indeed quite hard to make, unless one was thinking it could be made with iodine and ammonia, which unfortunately (or perhaps fortunately) doesn't result in NI3
Sort of, but it makes adduct of NI3 and ammonia NI3.NH3 which is good enough for "snappit" like behaviour.
