You will also need to plan where your condensate pipework will run to. It needs to be connected to a permanent drain or purpose made soakaway.
pumps can be used to add further flexibility
I think that if there is some one in the property over sixty or on benifits you could benifit from the Governments warmfront scheme
http://www.direct.gov.uk/en/MoneyTa...tsAndOtherSupport/On_a_low_income/DG_10018661
Tim
