When is a boundary not a boundary?
If directly below the external wall of a property is the pavement i.e. end of Terrace, I dare to presume you can’t terminate over the pavement as you have to be 600mm from a boundary.
What’s the scenario if you are intending to locate the boiler on the first floor of the property or in the loft and terminate through the gable end still above the pavement?
Is the boundary a vertical line upwards irrespective of height so termination anywhere on that wall is not acceptable? Or is there a height above which it is allowed. You haven’t got a choice other than to terminate over a boundary if you are in a block of flats on the 7 floor.
In fact, even if you are on the ground floor of a block of flats you potentially can’t but terminate beyond your boundary.
Anyone looked into this to get an official line?
