Then it's not behind....The cable is coming from behind and to some extent is concealed however at certain angle the hole would be visible
If for some reason I wanted to fit a surface pattress with a switch or socket etc, rather than a flush one, I wouldn't have the cable coming out of the wall next to it, I'd have it behind it...
I'm getting confused now - do these cables come out of the floor or the wall?Do you think its a good idea having something similar to these fit into the floor from which the cables appear rather than have the cable coming through the wall and having an issue keeping the hole neat?
Firstly yes they are coming from behind but some some devices are as such that they cant be fixed flush to the wall hence a gap is visible behind where the cable hole is visible from certain angles
For your second question.
That is a seperate issue im trying to tackle.
The single cable grommets i need for devices where of course a single cable is coming out of the wall for like a PIR etc
The multiple cables problem ive raised is for my CAT5e cables that are going to be bundled together for my computer netwokr and connect into the network hub. I need to "neaten" that hole where they are going to appear from and if i have several cables appearing from the wall, god knows how id neaten them likewise im assuming i would have to get them to appear from the edge of the floor or something
thanks
