Hi there, hoping to find an answer on this as I've read varying opinions across the net.
We had a new bathroom installed earlier in the year and part of that is a Mira thermostatic shower fed from our Greenstar 30si combi boiler. We have powerful mains pressure and our builder installed a PRV (initially set to 1 bar) on the cold feed to the shower. This is behind the bath panel.
Everything was fine for a while (in fact I'm not sure what could have changed) but then it started fluctuating in temperature and more recently emitting a loud whine that can get really loud. Scared the **** out of me last night, it was that bad.
I've spoken to Mira today and they've told me the PRV is far too close to the shower and in fact it should be on the main as it comes into the house - ie before the boiler and everything else - set at 3 bar. They don't believe it's a problem with the shower itself because they had me test turning a tap on when it's whining and sure enough the noise stops instantly.
However my builder says he's fitted loads of showers and laughed off the idea of reducing the pressure to the whole house saying he's never done this. For now he's asked me to try increasing the setting on the PRV and see if it sorts the problem.
So my question is, who is right? Should the PRV be near my stop tap and reduce the pressure to the entire house, or is my current setup okay and simply needs adjusting?
