Hi
I want to fit an automatic air vent to my central heating system as it does not have one at the high point. I've seen loads of products that look like a small bottle that screws into the system. I've read on one product installation guide that it cannot remove air from the system, when circulating, if mounted directly into a pipe. The diagram shows a chamber that the automatic air vent should be mounted above but I do not know the name of this. I would really appreciate some help in answering..
a) What is this chamber piece called?
b) Should I use this chamber peice or just mount the automatic air vent to a pipe at the highest point?
c) What is a known, good automatic air vent to install?
d) Can I mount this automatic air vent, at the highest point, which happens to be BEFORE a combined vent & cold water feed pipe? or does it have to be after the vent?
Many thanks
Rob
Many thanks
Rob
