Where to put the pump
28 Dec 2006
Yorkshire
hi lived in the bungalow 7 years just put my third CH pump in could this be in the wrong place it pulls the hotwater from the boiler and then pumps it to the three way valve so it pumps the hotest water any ideas could i just turn the pump round thanks rob
Theyre designed to take the flow temps. What make pump you using?
You may have sediment from corrosion getting into the pumps. Do you ever have to bleed the radiators? Is the water black?
the make of pump now is a grundfos , no probs with having to bleed radiators but if i take one off there is black sludge/water in the last bits thanks to all
