hi
the toilet in my house takes ages to fill. after a quick google i'm led to believe a good first attempt at a fix is to replace the inlet valve? can you advise where it is in this type of fitment, is it under the blue cap on the left? i notice when i press down on the white arm coming from there that the water comes out a bit faster. does this indicate faulty inlet valve?
also, if it 'is' under the blue cap, is this likely to screw or prise off? don't want to break it!
