Which adhesive for lino?
28 Oct 2005
Daventry
Hi
I need to peel up the corner of some heavyweight lino for a job in a few days time in a men's toilets. It's laid on a plywood base floor. What is the best adhesive to use to stick it back down when I'm done? Presumably it'll need to be something waterproof...
Cheers in advance
Not sure, how do you tell? It's about 2mm thick (roughly) and slightly metallic in appearance, but fairly smooth.
sounds like a vinyl covering rather than lino. vinyl is flexible where as lino is not.
You need acrylic adhesive for vinyl and lino adhesive for lino!
FBALL make the adhesive you need. (f44/F46 for vinyl)
