WHICH CONCRETE BLOCKS TO USE
3 Sep 2013
Blackpool
I am thinking of putting my 12 x 8 ft shed on a base similar to this -
but instead of just having the 4 concrete blocks and 2 bearers , i will be using 3 8ft bearers and 9 concrete blocks .So it will be 3 rows spaced out evenly instead of 2 like in the picture with a concrete block at each end and also in the middle of the bearer.
I will dig out the nine holes add some hard core (that i have lying around) in and tamper it down then put in the blocks and get them level for the bearers to go on.I will be adding landscaping fabric to stop the weeds and some DPM between the blocks and bearers.This seems easier for me to get my uneven ground level.The base will just sit above ground level by about 2inch or so and gravel on top of weed fabric.
What would be the best and deepest blocks i can use to sit the shed on ? i am looking to keep costs down .
Thanks :D
Anyone know which are the best blocks to use that will not deteriorate or crumble with the weight of the shed .. usually some blocks have a number don't they for strength ?
It would be better to forget the hardcore and use actual concrete cast in Then if you need to raise height use blocks. If you want to go ahead with your method use dense 7Newton blocks
I'm not an expert but dense concrete blocks should be fine. If I was building that I'd much prefer to use shuttering and pour in concrete as supports. Your real task is to get all of them exactly level.
