Which cylinder - standard or ACV?
22 Sep 2008
Bradford
What would provide more hot water a 500 litre standard coil cylinder, or a 400 litre ACV tank-in-tank cylinder. It is for a large house (linked to my earlier 50kW output boiler post). The property has six separate bathrooms with all the usual draw off demands.
I know the ACV would perhaps be more responsive in terms of reheat but the larger capacity cylinder may be the better option. Has anyone got any recommendations from previous installations?
I don't think the ACV 400 comes with an immersion either?
One will provide 100 litres more than the other.
Coil size of a normal cylinder likely to be 20kw, heat requirement of an ACV likely to be 40-60kw.
Neither the correct solution for 6bathrooms with rain heads.
The ACV as you can reheat it faster.
If demand is very large you might need to think of more than one cylinder and an accumulator tank.
What would the correct solution be for 6 bathrooms with rain heads?
Would depend on how they are used, together/Seperate, flow rates etc.
These companies manufacture large capacity cylinders for a reason, I don't see why this is not a suitable system for the property. In the context of capacities available a 400 or 500 litre cylinder is small, you can get 1000 - 2000 litres models if you require them.
2 x accumulator stores will also be installed to provide a better flow rate.
There are a couple of 300mm dia shower heads and a number of 200mm shower heads (no body showers etc.)
The $64,000 dollar question! I know flow rates but who can actually say exactly how often, when and for how long they will be used??
Your the client surely you know how likely 6 showers will be ran together or how likely someone will fill 6 baths conseqatively.
I would say 4 may be likely to be run together (for how long - who knows). It comes down to how people use the showers and how long they intend to stand under it 5 mins, 8 mins, 12 mins ?? I appreciate it is unlikely 6 showers would be running at the same time and there has to be an element of diversity
No space for 2 boilers but room for 3 cylinders totalling 1100 litres.
To me your mind is made up, you have the chance of running 120lpm if all showers are used.( that's quite small for a rainhead)
80/40 so 5 or 6 mins of showering then a full recovery.
