- Joined
- 24 Jan 2004
- Messages
- 121
- Reaction score
- 0
- Country
Hi Guys, sorry if this duplicates anything, in my lounge/dining room (open-plan) i have 2 rads, they're not up to scratch so i'm replacing them. I have worked out the BTU's required for the room and checked that my combi can cope with the more powerful rads. My problem is that the 2 rads that i have now are 1150mm long and the ones i'm replacing them with are 1000mm long, there is no scope without expense to move the pipes so i want to place 75mm spacer pies between the new rads and the original pipework (1000mm rad + 2 75mm spacer pipes = 1150mm). A guy at work who used to be a plumber has offered to make the pipes up for me if i buy the fittings and pipe, but when i went to my local hardware store the guy said don't bother getting it soldered use compression fittings instead. Is this viable? I have never heard of using compression fittings on central heating systems is it safe practice? Sorry if i'm asking a stupid question but i'm only a DIYer and as safety is paramount i don't want to get talked into something dodgy.
Thanks for any help you can give.
