Which storage/high flow combi?
18 Mar 2014
It's about time I replaced the back boiler open vented system in our house to a more modern system.
We have two bathrooms served by a piddly cylinder which doesn't keep up with demand.
I know from searching for similar discussions that an unvented system would be the preferable solution, our heating engineer also said that the uv option is the best. However, the space for a separate boiler and cylinder is not there, so it's not an option. Whatever system we choose will have to sit in the airing cupboard where the existing cylinder is.
So we're left with the idea of a storage combi, while using the ex cw tank as a break tank with a monsoon extra to boost the cw feed to the combi.
So which brand and model should I go for? My installer reckons a wb highflow, he's installed them before and says that if the water flow and pressure are man enough then they are great, and he can offer them with a 4000 year warranty. But are there any others I should consider? I see viessmann do one which is pricier, and glow worm do a wall mounted one for about 1200 quid. Are either of these worth considering?
Thanks in advance for your advice
I would be looking at the Vaillant 937. Great boiler and reliable too.
7 year warranty if fitted by Advance installer.
glow-worm ultrapower sxi, I fitted one a couple of months ago and customer feedback very positive about this setup.
Thanks Jeff for your suggestion. A long warranty like that is certainly reassuring.
I think one of they key points to consider, which I forgot to ask, would be what is the hot water generation like once the store has been depleted? Only wb seem to publish this data in their literature (19 l/m on the 550, and 14 l/m on the 440)
Yeah I've looked at these, a big fridge of a unit like the viessmann, I can't find anything on glow worm's site though? Are they discontinued?
No definately still available, no idea why there is nothing on there website, maybe they "forgot" to put it on.
Worcester 440 or 550 fiited loads, brilliant boilers and you ll get a 7/8 yr warranty if fitted by an accredited installer :D
never had one break down but nice to have the back up if req'd
