whirlpool baths
12 Jan 2005
whats the best way to drill tap holes on acrylic baths just a normal holesaw or something different is there a template suppopsed to come with it it s a mixer tap any tips greatly appreciated also once taps are done and connected is the whirlpool bath no differnt to fitting ordinary bath apart from electrics many thanks
They're deeper so you may have to cut a section of floorboard out to accomodate the trap. Therefore where the bath waste enters soil stack could be an issue also - might need lowering ie new strap on boss.
do not forget that whirlpools have jets all the way round so acess all the way round must be considerd. also to minimise pump noise insulate inside bath pannel but do not restrict air flow to the pump. pump can be mounted on rubber mat to reduce vibration
its a good idea to test test and test again before fitting paying attention to correct operation of level sensor(if fitted) and to identify any leaks.
water & electrics! FIT 30 ma RCD and use ip rated junction boxes
