I'm having trouble with a whirlpool dishwasher Model GU940SCGB2. It will drain part way, then stop. If I go to the Stop/Drain button, sometimes it runs for about 20 seconds, then stops, other times it won't run at all. Eventually it simply shuts off with a great deal of water left in the machine.
I read through the posts for several years back looking for similar problems. I noted in a post from April 06 that a different Whirlpool model had a check valve that might be clogged. Would that apply to this model and if so, where would I find it. Could you suggest other possible solutions?
A local appliance repair immediately told me I'd need to replace the pump/motor assembly before even looking at it. That seems a bit extreme to me. Am I simply nieve?
Thanks in advance.
Thanks in advance.
