whirlpool washer
24 May 2008
Texas
when water is draining from washing machine it is coming out where drain pipe enters the standpipe. is this the machine or something else. we replaced an old washer for this reason it was ok for awhile but problem is back. lines have been checked, the pipes have been checked for blockage, and nothing has been found.
must try harder.
i used to work for HP (washer company) had exactly same thing, i was able to pull stand pipe off and use it as a telescope, guess what , you could see blockage, gave it to customer and left.
washers pump out fluf and stuff this sticks to pipes causing blockages, take all pipes off and hold to a light (like telescope) one will have something in it
