Whirlpool washing machine Model LHA5300Woo old top loader
27 Sep 2009
Texas
This machine will not empty water after wash, the pump sound like its working, but to no effect, can drain it by puttiong hose below water level, so i don't think its blocked.
Hope you can help.
Most of these the pump is driven by the main wash motor so if the drum is working the motor is ok.
Check the pump itself for damage or a blockage (socks are quite common) so check the hoses just in case.
The impellor can get worn out on some of these (the blades wear out and although the shaft spins it cant shift any water)
