we have heard this argument many times mate, all flues are made with the same PE, just another way of getting out of these daft extended warranties , then there is the new one about terminals melting if fitted at high level , you couldnt make it up
Thought it was a bit odd...I always fitted baxi and have never seen that in instructions...still no mention of uv damage.Does strike me as v v unusual.
I have never actually seen the UV rationale written down in any MI’s I was verbally told that over the phone from Ideal (I think!). In fact as I said previously I’ve only actually seen the ‘no white showing’ in one MI’s despite numerous others not allowing it . I rang Worcester today to confirm and they said absolutely fine no issue.
I was also going to suggest taping or wrapping them up... Take it this is permissable? Closure tape?
But surely that would eventually weather and come off or look nasty?
When I spoke to Baxi they suggested as already mentioned taping the last 3 inch was acceptable. Baxi said their flue has a ring approximately 3 inches back from the terminal and many people had mistakably considered this where the rubber collar should sit and hence white would be showing and so to get over this taping that but was acceptable!!!
If it’s acceptable to tape up the 3 inches why isn’t it acceptable to tape the last 12 inches. It’s either acceptable or not as an approach. Taping up, which will ultimately fall off, is a fudge and will look terrible in no time. So in my opinion it is a none starter.
