    Dismiss Notice
White top coat for pebbledash repair??
Discussion in 'Plastering and Rendering' started by siggymum, 25 Apr 2010.
  1. siggymum
    siggymum
    24 Apr 2010
    3
    Thanks Received:
    Ayrshire
    Country:
    I've repaired a couple of 'blown' patches on my wall and have done the base coat with sand/cement mix which is now drying out. How/Where do I get the white cement for the top coat to tie in with existing 'dash? Does it come as a complete mix or do I need to mix with sand and do I add PVA to the top coat mix as well?
    This is my first attempt at anything like this so...be gentle with me!! :confused:
  2. Sponsored Links
  3. Alastairreid
    Alastairreid
    21 Nov 2008
    6,502
    Thanks Received:
    1,039
    uk
    Country:
    its called snowcrete and you need to add sand! if its a white background use white sand.
    dont use pva either use mortar plasticiser.
    you should get it in your local bm.
    • Thanks Thanks x 1
  4. siggymum
    siggymum
    24 Apr 2010
    3
    Thanks Received:
    Ayrshire
    Country:
    I used ordinary sand/cement mix not white sand for base, will it be okay with the white on top or will it show through?
    Sorry if I appear thick as cement but haven't done this before and don't want to have to redo :confused: :oops:
  5. joe-90
    joe-90
    28 Oct 2005
    31,284
    Thanks Received:
    1,062
    Country:
    White cement and yellow sand look very yellow when dry. Your best bet is to get some old discoloured render and mix that with white cement.
    • Thanks Thanks x 1
  6. Alastairreid
    Alastairreid
    21 Nov 2008
    6,502
    Thanks Received:
    1,039
    uk
    Country:
    absolutely fine! thats the way its normally done.
  7. siggymum
    siggymum
    24 Apr 2010
    3
    Thanks Received:
    Ayrshire
    Country:
    Thanks for advice guys ....will let you know how I get on :rolleyes:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
