Whole tile not stuck and cannot lift becasue of underfloor h
3 Apr 2007
Tyne and Wear
Hi there i have put underfloor heating down and tiled on top with slate, all looks fine but one of the tiles is not stuck down on about a 3rd of the tile and there is some movement.
I have tried putting some spacers underneath to take the strain and i cannot lift the tile because it could ruin the underfloor heating wire.
Has anyone got any ideas as i am worried that the grout will always crack on the joint?
Thanks in advance
so your sure you cant lift the tile up definatly without causing any damage at all?
how wide are the joints? if they are 4 or 5mm you might be able to make some adheisve up, but really runny, and pour it into the grout gaps and let it set, but leave it a lot longer than you would normally for obvious reasons, then you should have sorted the problem, re grout with the same as before as to make it similar!
Hi there the tile is well stuck down apart from the end and the gap is around 3-4 mm so i suppose the runny adhesive is an option to try unless there are any other suggestions?
