I noticed two different brands of 3-column radiators which are both of the same 1800mm x 470mm size.
https://www.bigbathroomshop.co.uk/m...n-radiator-1800mm-x-470mm-triple-column-59378
5193 BTU at Delta T50
https://www.radiatoroutlet.co.uk/18...quered-vertical-traditional-3-column-radiator
8218 BTU at Delta T50
Is it possible that two 3-column rads of the same size would genuinely have such a discrepancy in the BTU output when measured at the same Delta T? If this is genuinely possible, why is it that there would be such a discrepancy e.g. the material the rad is constructed from or the manufacturing process, or some additional design feature?
Thanks.
Thanks.
