- Joined
- 27 Jan 2008
- Messages
- 29,241
- Reaction score
- 3,586
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have lived in a house that circulates the DHW and yes it works in that you have hot water within seconds of opening the tap, however the pipes need to be well lagged, or it will heat the home in summer, also you don't want the water circulating at night so the pump needs a timed pump and clearly if the pump is not running you don't get fast hot water. So it ended up not being switched on in the summer as it got the house too warm as the insulation was not good enough.
Using hot water direct from a boiler be it an independent boiler or combined with the central heating unless so small heat store is included it means a further delay getting the hot water, if a heat store is included using a shower the water goes from cold to hot back to cold and then hot again as it uses up the heat store, and without the heat store you have to turns taps full on to get the boiler to cut in.
There is also the pressure, for potable water you don't want it to share same pipes as stored water, so you need the special mixer taps that only mix water as it leaves the faucet, and it often means non potable water in the bathroom to get pressure the same, so need bottled water to clean your teeth.
There are pros and cons with both systems, and water tanks do take up a lot of space.
I got rid of the hot water tanks in my old house, and fitted a Main 7 direct heat boiler, which resulted in being able to use a thermostatic shower in the bathroom, lost a little space in the garage, but gained enough space upstairs to make airing cupboard into a bedroom, yes we needed to run more water to get the hot water, but since higher pressure it came through just as fast. But it also stopped all ideas of heating the water using solar power, or back boiler, or immersion heater.
In this house shower is direct electric as not enough pressure to use thermostatic mixer, OK I know there are tanks today which can give mains pressure to the hot water, but they are expensive, and if you already have a tank then to renew tank and boiler gets rather expensive.
Mother house had the two boilers combined, the combi boiler, mine was two independent boilers, but only difference was her boiler was well over sized for the house, not sure why it was so big, mine I seem to remember was 18 kW plus 18 kW for house, hers was 28 kW with single boiler, and both houses had the same problem, you needed large shower heads or in summer the boiler would cut out.
Before the combi was fitted to mothers house she had a power shower, only way to get enough pressure.
I now don't have the option, oil boiler don't modulate like gas, so have to use a water store, the work in fitting return pipes means the circulating pump is a non starter, and having 22 mm pipes for hot water means I run a lot more cold water than I would with a mains pressure hot water supply with 15 mm pipes.
This was part of the problem with last house, when the main 7 was fitted it no longer needed 22 mm pipes, but they were already fitted, so took ages to get hot water to kitchen sink. When mothers house was done, all the old pipes were ripped out, and new pipes fitted, so with the smaller pipes water reached hot taps much faster than before combi was fitted.
To start from scratch if you have the room, then a nice new storage tank with mains pressure hot water with 15 mm pipes and circulation pump would be better than a combi, but also a lot more expensive, if reusing what is already fitted then much depends what is already fitted. And as to circulation pump you really do need to insulate the pipes well or it heats house in summer, and if you do insulate well not as much need to circulate anyway.
I will admit I am considering a local hot water store for the kitchen, takes to long to get hot water through, if I had a local hot water unit in kitchen then in summer I would not run the boiler, shower is instant electric and to heat 40 gallons of water do I can wash my face with warm water in the morning I don't think so. I would just have a shower.
