Hi
I have installed a header tank in the loft for a rain water harvesting system and as per design it has a 40mm overflow pipe to the outside.
I see that overflow pipes sometimes have a 45 degree angle cut on the outlet end.
What is the purpose of that cut and do I need to make one or can it be left stright?
The second question is whether I should put some form of grill, self sealing waste or one way valve on the pipe. I am just wondering if at 40mm there is a chance that flying insects/wasps might find it as a way in to the loft. Thoughts?
Thank you for your help.
