Hi all,
I need to widen my fireplace by about 10 more cm to take an insert stove.
Head on:
As you can see there is no obvious lintel.
The left side seems fairly 'solid', I can't punch through:
So that side is 'real'
Now this is what stumps me, the right side is hollow: See below.
Looking through that rectangular hole towards the front you can seen a single row of bricks maybe 1.5 to 2 bricks long: See below.
Looking towards the back you can see the wall with a part layer of extra brick. And what looks to be old gas/water pipes from a time the house may have had one of those ubiquitous 'council' type gas fires with a back boiler:
The question:
Can I just knock out that single row of bricks on the right side to widen the opening? Or is that load bearing? Has anyone seen this sort of thing before? Why no lintel?
Extra info
House is an early 70's - late 60's detached 3 bed. There is no chimney brickwork visible on the outside wall. There is a small breast <2ft across coming though the bedroom above.
Heres a view up the opening if that will help any of the experts: See below
Thanks, suggestions welcome.
Head on:
The question:
Extra info
