Those windows look like theyve been glazed with face putty.
that’s going to be a real nightmare to do - you will spend most of your time trying to get rock hard putty out of the rebates. You won’t get a tradesman interested in trying to do the job.
your 2nd problem is the rebates will only be around 10mm and standard double glazing needs 12mm spacer + 4mm air gap min.
if you choose slim line glazing, you will suffer premature failure of the units - unless you really know how to fully encapsulate properly.
Your best route is to simply replace the sashes - in which case the rebates could be tweaked to suit your new glazing.
