Why don't you use a bulb?i mean just something that would simulate what the bulb does to become a load, in other words i want to make an artificial load
The bulb doesn't force the electrons through, it restricts their flow so that they are forced though by the pressure behind them (voltage) causing heat.so when i make a circuit out of my artificial load i know that it will not spark or heat up the wires. to my understanding the light bulb becomes a load by forcing the current to pass through the thin filament
What do you have against bulbs?and then the electrons leave the light bulb and go to negative terminal of the battery without a problem, so is there some demonstration online somewhere where i could simulate this same thing without the actual bulb.
Yes. It won't take long.if it is true that after the bulb forces the electrons through the filament they go back to the negative terminal without a problem can't i use a little wire or something like that to simulate a filament and use it as my load in the circuit instead.
Everything is a load.all this is part of a trying to gain a deeper understanding of what makes a load, a load.
We are controlling the circuit so that it does what we want.
It would if it weren't large enough to handle the current.what is it about passing through the load (the bulb or a motor, etc ) that now lets the electrons go back to the negative side of the battery without heating up the wire now.
That is because the load is restricting the flow (and is able to do this without being destroyed) instead of allowing an unrestricted flow of electrons which would destroy the cable.if the circuit has no load it would just heat up the wire and spark, but if the circuit has a load it would not heat up the wire to the negative terminal.
