Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
How do I wire an outside PIR to a wall light inside the porch which is fed from a switched FCU the other side of the mounting wall. Does the pir wiring require an earth?
Do you have the manufacturers instruction? As the wiring diagram will answer your question.
In simple terms a three core cable/flex (live, neutral, cpc/earth) that is suitable for the external environment and external effects, from FCU to senor, terminate live to L, neutral to N and CPC to E. Then 3 core back to light from senor L1-live, N-neutral, E-CPC, then to their corresponding terminals on light.
But some may differ, so ideally would require product details.
